Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Turbo noob's q
Thread: Turbo noob's q
Old 05-08-2007, 04:06 AM   #1
2Slow2Race
Fan#: 46446
What I Drive: 2003 Oyster Silver Euro Sedan
FF Reputation: 1 2Slow2Race Good Standing Member
Turbo noob's q
As you'd probably guess while reading, I know jack- about turbos. Found a shop here that sells these turbochargers for pretty affordable price (300-400euros), so I need a confirmation if any of these turbos will suite my cars needs, looking for a low boost kit.
My car is a 2003 Zetec.Here are the specs:
- Turbo T3
Brand New T3 Turbo 4 Bolt Exhaust Flange.42 cold a/r • .48 Hot • 2" OUTLET • Great Turbo for 1.6L to 1.8L engines • Spools on a 1.7 @2700 • TURBINE WHEEL: EXDUCER: 1.81", MAYOR : 2.48" • COMPRESSOR WHEEL: EXDUCER: 1.67", MAYOR : 2.36"
- Turbo T3/T4
HYBRID T3/T4 T04E TURBOCHARGER STAGE III WHEEL,.50 A/R COLD,.63 5 BOLT STANDARD HOT SIDE,3" INLET DIAMETER, 2" OUTLET,.57 COMPRESSOR WHEEL TRIM,.60 A/R COMPRESSOR,.63 A/R TURBINE,57 TRIM,TURBINE WHEEL:EXDUCER: 2.48",MAYOR : 2.89",COMPRESSOR WHEEL :EXDUCER: 2.07",MAYOR : 2.36"
- Turbo T3/T4 with internal wastegate
Turbo .50 .63 3" VBAND EXHAUST 6.0 PSI INTERNALLY GATED TURBO • FORD SPRINGVALVE ACTUATOR • HYBRID T3/T4 • T04E STAGE III WHEEL .50 A/R COLD .63 3" SUPER VBAND OUTLET, 3" INLET DIAMETER ,2" OUTLET .57 COMPRESSOR WHEEL TRIM ,.60 A/R COMPRESSOR, .63 A/R TURBINE 57 TRIM
P.S. - the kits say they are designed to run at 0.4bars of boost. Will that be ok with stock internals?
Will ANY of these suit the Zetec as part of a custom turbo kit and, if they do, which one of them will be the best to get, since they're all within a resonable price variation.
Thanks,
Alek
2Slow2Race is offline
