Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - The go faster thread: Stage 1
Old 04-27-2004, 01:25 AM   #4
mofocus
mofocus's Avatar
Fan#: 5
What I Drive: Beltfed,extra pullified,weeemachine
FF Reputation: 6 mofocus Good Standing Member
Buy-Sell-Trade Rating: (17)
Throttle Bodies
this part is a favorite for most. While the horsepower gain is minimal, the throttle response added by an upgraded throttle body is definatley noticable and a good gain for the money there are several to choose from. the install can also be tricky if you are unfamiliar w/ the part and work needed. if you are unsure, while this is one of the easiest installable pieces, it is better safe than sorry. *note* most automatics transmissionsfrom require special brackets
HOW TO INSTALL(ZETEC)
SPI engine
Focus Central 60mm tb
BDR throttle body (also allows use of ZETEC intakes
ZETEC
FC 65mm throttle body: billit, comes in color of choice, be sure to get correct year make
NEW EDGE PERFORMANCE 00-02
NEW EDGE PERFORMANCE ATX 00-02
ATX BRACKET
if you ordered one of the above w/o it (yes you must have it for an ATX from 00-02)
MY FORD PERFORMANCE
MY FORD PERFORMANCE 03 ATX/MTX
FC 70mm throttle body: race applications only, idle bypass has been deleted. for 5 speed
MY FORD PERFORMANCE
BBK throttle body: allegedly as good quality as FC
MAD PERFORMANCE
Jackson Racing 65mm TB
JACKSON RACING
SVT
MY FORD PERFORMANCE
Duratec
NEW EDGE
PERFORMANCE
another low budget option for some is to port your stock throttle body, while there isnt as much gain as there is from using the bigger bore aftermarket throttle body, the price of you doing it yourself is certainly affordable by almost everyone w/ a dremel
MAY 2007 ROTM WOOT
[/COLOR][/B][/U]
my dyno video
mofocus is offline
