Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - JRSC parts list and manual - where?
Old 05-03-2007, 10:27 AM   #4
Turbo Turtle
Fins Up!
Turbo Turtle's Avatar
Fan#: 32772
What I Drive: STi & Miata
Points 22,252, Level 92
Points: 22,252, Level: 92 Points: 22,252, Level: 92 Points: 22,252, Level: 92
Level Up 91% Completed
FF Reputation: 55 Turbo Turtle Excellent Standing Member
Buy-Sell-Trade Rating: (25)
i have the instructions too. the book mark for that is saved on my computer at the house i will have to get that to you when i get home.
Here is the list of parts with the part numbers .
Item No. Description Quantity
995-000 SUPERCHARGER SYSTEM 1.00
988-042 S/C SUPPORT BRACKET KIT 3 1.00
051-081 WASHER, FLAT, M10 2.00
051-084 BOLT, HEX, M10-1.50 X 50 G8.8 2.00
051-186 NUT,FLANGED,8X1.25,12AF 1.00
051-505 BOLT FLANGED M8X25X1.25 12 AF 1.00
051-506 BOLT, HEX FLANGE M8-1.25 X 30 1.00
051-657 BRACKET, S/C SUPPORT STRAP 1.00
051-658 BRACKET, S/C SUPPORT LOWER 1.00
772-316 ALUMINUM, 2.7X4.7X1.125 1.00
772-217 BLACK, ANODIZE 0.56
988-105 ALT/BELT DRIVE BRACKET - FOCUS 1.00
051-081 WASHER, FLAT, M10 1.00
051-505 BOLT, HEX FLANGE M8-1.25 X 25 2.00
051-627 PULLEY, 2.0IN IDLER, PLASTIC 1.00
051-762 BOLT,HEX FLANGE,M10 X1.25 X 30 1.00
052-170 BRACKET, ALTERNATOR - GEN. 2 1.00
988-211 INTAKE MANIFOLD ASSY - FOCUS 1.00
051-098 BYPASS VALVE 1.00
051-121 SCREW, SHCS, M6 X 1.0 X 16 4.00
051-142 HOSE BARB, 5/32 VACUUM 2.00
051-144 HOSE, SILICONE, 1.5 ID X 1.25 1.00
051-189 CLAMP, HOSE, MINI, 2INCH 2.00
051-364 PLUG, PIPE, AH, 1/4 NPT 1.00
051-503 BOLT M8 X 0.75 X 10 WI PLUG 1.00
051-529 GASKET, JR BYPASS-MANIFOLD 1.00
051-553 CLIP RETAINING 7/32 VACUUM 1.00
051-660 INTAKE MANIFOLD - FOCUS 1.00
051-794 GASKET, INTAKE MANIFOLD 1.00
051-796 HOSE, VACUUM, 7/32 X 14 IN 1.00
051-551 HOSE, VACUUM, 7/32 ID, BULK 14.00
051-797 HOSE BARB,1/4NPT X 1/2 X 45DEG 1.00
988-307 SUPERCHARGER ASSEMBLY - FOCUS 1.00
051-122 STUD, M8 X 1.25 X 40 1.00
051-142 HOSE BARB, 5/32 VACUUM 1.00
051-207 AHCS M8X1.25X25 2.00
051-528 GASKET,GEN3 S/C-TB ADAPTOR 1.00
051-656 S/C GEN3 M45 CW 3.0-6R 1.00
051-662 TB ADAPTER FOCUS 1.00
051-680 HOSE BARB, 3/8 VACUUM 1.00
051-783 AHCS, M8 X 1.25 X 55 1.00
051-938 NUT, FLANGE, M8X1.25, 10MM A/F 1.00
988-423 HOSE BAG 1.00
051-134 VACUUM TEE 3/8 1.00
051-235 CLAMP, HOSE, SAE NO. 44 2.00
051-259 HOSE, VACUUM, 5/32 IN., BULK 35.00
051-389 TEE, VACUUM, 3/16 1.00
051-513 CLAMP, HOSE, NO 8 2.00
051-665 HOSE, PCV, 1/2IN BULK 2.00
051-669 HOSE, FLEX LOPRENE 1.00
051-758 HOSE, SILICONE, 7MM ID, BLACK 32.00
052-201 TEE, VACUUM, 3/8 X 1/4 X 3/8 1.00
052-211 HOSE, VACUUM, 1/4, BULK 6.00
770-268 LOOM SLIT, CONVOLUDED, 1/2 DIA 36.00
051-320 ELBOW,VACUUM, 1/8X11/64X90 DEG 1.00
051-372 SLIT LOOM.1/4 INCH 12.00
163-655 HOSE, VACUUM, BLACK PLASTIC 3.00
988-703 GASKETS - LOCTITE - ZIP TIES 1.00
051-016 CABLE TIE 8.00
220-136 REMOVABLE THREADLOCKER 1.00
051-525 GASKET, M45 S/C MANIFOLD 1.00
051-395 SPADE CON, MALE, 18-22 GA 1.00
051-387 SPADE CON, FEMALE, 22-18 GA 1.00
988-812 INSTRUCTIONS AND STICKERS 1.00
051-473 JR WARRANTY CARD 1.00
051-676 INSTRUCTIONS FOR FOCUS 1.00
052-010 STICKER, PREMIUM FUEL REQUIRED 1.00
052-282 CARB E.O. STICKER 1.00
988-913 HARDWARE BAG 1.00
051-004 BOLT,HEX FLANGE,M6 X 1.00 X 15 4.00
051-074 WASHER, FLAT, M8 4.00
051-075 WASHER, LOCK, M8 4.00
051-119 BOLT, HEX FLANGE M6-1.0 X 10 1.00
051-125 STUD, FULL THREAD 8 X 50 X1.25 9.00
051-127 BOLT, HEX FLANGE M8-1.25 X 20 1.00
051-135 BOLT, HEX FLANGE M8-1.25 X 40 1.00
051-186 NUT, HEX FLANGE M8-1.25 9.00
051-663 SCREW, SET, M8 X 1.25 X 50 2.00
051-677 STUD, M10 X 1.5 X 50 1.00
051-678 NUT, FLANGE, M10 X 1.5, 15 AF 1.00
051-714 BRACKET, SC - ALTERNATOR 1.00
051-717 SPACER, .33 ID X .63 OD X .33 1.00
770-137 ALUMINUM, ROD, 0.625 0.53
051-718 SPACER, .33 ID X .63 OD X 1.80 1.00
770-137 ALUMINUM, ROD, 0.625 2.03
051-754 ALLEN WRENCH, 4MM 1.00
051-761 BOLT,HEX, M8 X 1.25 X 90 4.00
051-788 BOLT, HEX FLANGE M10-1.5 X 40 2.00
052-911 BELT, 6PK2655 1.00
988-915 HARDWARE BAG 1.00
051-003 BOLT, HEX FLANGE,M6 X 1.0 X 12 4.00
051-728 BRACKET, MOUNTING, P/S 1.00
051-729 BRACKET, ADAPTER, P. STEERING 1.00
051-787 NUT, FLANGE, M6 X 1.0, 10 AF 4.00
051-789 SCREW, TAPPING, M6.3-1.81 X 20 1.00
051-696 BADGE, JACKSON RACING 2.00
052-404 DFMM - FOCUS ZX3 1.00
052-405 FUEL CONTROLLER ZX3 1.00
052-071 LICENSE PLATE FRAME, JR 1.00
051-381 BOX, 30 X 15 X 15 350LB TEST 1.00
051-889 BOX, 15 X 15 X 5 1.00
051-942 BOX, 24 X 14 X 14, 275LB TEST 1.00
Turbo Turtle Garage
Zetec and Duratec Turbo kits, engine building
turboturtlegarage.com
facebook.com/TurboTurtleGarage
Turbo Turtle is offline
