Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Car stalls when making a turn...
Old 05-01-2007, 10:37 PM   #7
TheGlobster
TheGlobster's Avatar
Fan#: 44234
What I Drive: 2000 Focus ZX3
FF Reputation: 11 TheGlobster Great Standing Member
Does the problem happen when the tank is full or nearly empty?
Look, just try a simple test. Get your fuel level down to 1/4 tank. Find a good stretch of empty road or an empty parking lot without cement stops. Take the car to 45 mph and turn. Try to reproduce 3 times. If you can reproduce it, then fill up the tank and try the same thing. If it stops happening, your problem is the fuel pump. If it continues to happen, it may be something else (still probably the fuel pump, though).
Pause and think how in God's name this problem could be electrical. The only way I can see is that the fuel pump needs to work harder and the power draw is bothering the electrical system. Maybe that, or the sway of the car is pinching some component. Or maybe the battery fluid is low and the sway of the car in a turn cause a broken circuit. Who knows.... Did the Ford dealer offer you an explanation of HOW the problem is electrical?
Is the battery new? Have you cleaned your injectors and changed the fuel filter? How many miles on the car and have you followed recommended maintenance?
Previous Owner Mods: 4-1 long headers, MBRP Exhaust, Short Ram Intake, Strut Bar, Neon Lighting
ME: Bosch IR Fusion plugs, Back Cat, Kazera KZ-V Rims & Pirelli 215/45ZR17ís
(Next Project: add Throttle Body)
TheGlobster is offline
