Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - General specs on the SPI
Old 04-18-2007, 11:20 AM   #1
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
Points 13,156, Level 74
Points: 13,156, Level: 74 Points: 13,156, Level: 74 Points: 13,156, Level: 74
Level Up 77% Completed
FF Reputation: 175 b16sir1991 Excellent Standing Member b16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
I am going to list about all the specs that you guys may need. This is being done mainly because of all the questions that I get from time to time and Doug (WD-40) was talking to me about doing a sticky for you guys, so here you go:
First is the SPi cars:
General Specifications Item Specification
Displacement 2.0 Liters (121 CD)
Number of cylinders 4
Bore and stroke 84.8 mm x 88 mm
Firing order 1-3-4-2
Oil pressure (hot 2000 rpm) 240 kPa -450 kPa
Drive belt tension 178 N-311 N
Compression ratio 9.35:0.25
Coolant capacity 5.0-5.8 Liters
Cylinder Head and Valve Train Item Specification (mm)
Valve guide inner diameter (I.D) 8.063-8.094
Intake and exhaust 8.063-8.094
Valve seats width intake and exhaust 1.75-2.32
Angle 45 degrees
Runout (total indicated runout [T.I.R.]) 0.064 MAX
Bore diameter (insert counterbore diameter) intake 39.940 MIN.
39.965 MAX.
Bore diameter (insert counterbore diameter) exhaust 34.940 MIN.
39.965 MAX.
Gaskets surface flatness 0.04/26 0.08/156
0.15 Total
Head face surface finish 0.2/2.5 0.8
Valve stem to guide clearance intake 0.020-0.069
Valve stem to guide clearance exhaust 0.049-0.095
Valve head diameter intake 41.9-42.1
Valve head diameter exhaust 34.9-35.1
Valve face runout limit intake and exhaust 0.005
Valve face angle 45.5 degrees
Valve stem diameter standard (std.) intake 8.025-8.043
Valve stem diameter standard (std.) exhaust 8.006-8.017
Valve springs 4.3 turns
Compression pressure loaded 83.0 N @ 29.27
Compression pressure unloaded 350 N @ 39.53
Free length (approximate) 52.4
Installed spring height 39.53
Valve springs assembled height 39.53
Service limit, pressure lost @ specified height % 5
Rocker Arm Item Specification (mm)
Ratio 1.65
Valve tappet, hydraulic diameter (std.) 22.200-22.212
Clearance to bore 0.023-0.065
Roundness 0.013
Finish micro 0.2
Service limit 0.127
Collapsed tappet gap 0-4.5
Tappet bore diameter 22.25 0.15
Camshaft bore inside diameter no. 1, 2, 3, 4, 5 45.796-45.821
Camshaft Item Specification (mm)
Lobe lift intake 6.23
Lobe lift exhaust 6.23
Allowable lobe lift loss 0.127
Theoretical valve maximum lift intake 10.28
Theoretical valve maximum lift exhaust 10.28
End play 0.02-0.20
Service limit 0.20
Journal to cylinder head bearing surface clearance 0.03335-0.0835
Journal diameter standard 45.7375-45.7625
Runout limit 0.127 (runout of center bearing relative to bearing nos. 1 and 5)
Out-of-round limit 0.08
Camshaft drive assembled gear face runout crankshaft 0.65
Camshaft drive assembled gear face runout camshaft 0.275
Cylinder Block Item Specification (mm)
Head gasket surface finish roughness height (CLA) 3.8-2.0
Head gasket surface finish roughness height cut-off 0.8
Dowel height chamfer 0.8x30
Dowel height chamfer total 12.5
Cylinder bore diameter 84.8
Piston to cylinder bore clearance 0.020-0.040
Surface finish (RA) each bore min. 15-38
Average of all bores of a cylinder block (Ra) min. 20-30
Out-of-round limit 0.025
Tappet limit 0.013
Main bearing bore diameter @ 30 PF Bearing Cap P/L 62.2835-62.3145
Main bearing bore diameter other than above 62.2935 .0100
Crankshaft Item Specification (mm)
Main bearing journal diameter 57.98-58.0
Out-of-round limit 0.008
Taper limit 0.008 per 25.4 (l)
Journal runout limit (runout of bearing 2, 3, and 4) 0.05
Crankshaft end play 0.100-0.300
Surface finish (RMS) micro 0.3
Clearance to crankshaft 0.020-0.065
Thrust bearing journal length 28.825-28.854
Connecting rod journal length 28.825-28.854
Surface limit (RMS) micro 0.6 rear
Surface limit (RMS) micro 0.9 front
Main bearing thrust face surface finish (RMS) micro 0.6
Main bearing thrust face surface finish (RMS) rear micro 0.9
Main bearing thrust face surface finish (RMS) front runout limit 0.025
Runout limit (T.I.R.) 0.180
Flywheel ring (gear lateral runout (T.I.R.) manual transmission 1.5
Connecting Rod Item Specification (mm)
Connecting rod bearings clearance to crankshaft 0.020-0.065
Bearing wall thickness (std.) 1.476-1.488
Clearance of crankshaft without cylinder head desired 0.0457-0.0660
Clearance of crankshaft without cylinder head allowable 0.0461-0.0859
Clearance of crankshaft with cylinder head desired 0.0279-0.0483
Clearance of crankshaft with cylinder head allowable 0.0276-0.0674
Bearing wall thickness 2.117-2.129
Connecting rod piston pin bore diameter 20.570-20.610
Crankshaft bearing bore diameter 46.89-46.91
Out-of-round limit piston pin bore .008
Taper limit piston pin bore 0.0038/25.4
Length (center to center) 131.905-131.975
Out-of-round-limit bearing bore 0.010
Taper limit bearing bore 0.010
Alignment bore-to-bore (max. differential) twist 0.05
Alignment bore-to-bore (max. differential) bend 0.038
Side clearance (assembled to crank) standard 0.092-0.268
Side clearance (assembled to crank) service limit 0.356
Pistons Item Specification (mm)
Piston-to-bore clearance rebuild 0.020-0.040
Piston-to-bore clearance service 0.020-0.070
Piston diameter 84.77-84.80
Pin bore diameter 20.632-20.641
Ring groove width compression (top) 1.53-1.55
Ring groove width compression (bottom) 1.53-1.55
Ring groove width oil 4.008-4.032
Ring groove width compression ring (top) to ring groove clearance 0.04-0.08
Ring groove width compression ring (bottom) to ring groove clearance 0.06-0.09
Squish height 0.908-1.858
Piston pin length 66.2-67.0
Diameter standard 20.622-20.631
Pin to piston clearance 0.007-0.013
Pin to rod clearance press fit 8 KN
Pistons rings Item Specification (mm)
Piston ring width compression (top) 1.47-1.49
Ring width compression (bottom) 1.46-1.49
Ring width oil ring service limit (Side clearance) 0.15 MAX.
Ring gap compression (top) 0.25-0.28
Ring gap compression (bottom) 0.25-0.28
Ring gap oil ring (steel rail) 0.04-1.68
Side clearance 1st ring 0.04-0.08
Side clearance 2nd ring 0.04-0.09
Lubrication System Item Specification (mm)
Oil pump relief valve spring tension 41.4-45.8 N @ 28.1
Relief valve-to-bore clearance 0.02-0.08
Oil pump type Gerotor
Rotor clearance outer gear to housing clearance 0.074-0.161
Rotor clearance inner and outer gear to cover clearance (end play) 0.013-0.089
Rotor clearance inner to outer gear tip clearance 0.05-0.18
Oil capacity with filter 3.76 Liters
Lubricants Specification
Super premium 5W20 SAE engine oil XO-5W20-QSP WSS-M2C153-H
Silicone gasket and sealant F7AZ-19554-EA WSK-M2G343-A4
Crankcase conditioner B7A-19579-C ESR-M99C80-A
Torque Specifications Description Nm lb-ft lb-in
Intake manifold nuts 10+90 degrees 10+90 degrees 89+90 degrees
Intake manifold bracket nuts and bolts 10 89
Front engine accessory drive bracket bolts 47 35
Front engine accessory drive bracket nuts 47 35
A/C compressor bolts 25 18
Upper generator bolts 48 35
Lower generator bolt 48 35
EGR valve to intake manifold 25 18
EGR valve to EGR manifold tube 24 18
EGR manifold tube to exhaust manifold 6 53
Flexible exhaust pipe 47 35
Exhaust manifold nuts 27 20
Catalytic converter to exhaust manifold bolts 40 30
Oil control plug, iB5 transmission 35 26
Thermostat housing 13 10
Starter motor to transaxle 35 26
Lower transaxle flange bolts 47 35
Upper transaxle flange bolts 47 35
Left-hand transaxle flange bolts 47 35
Engine roll restrictor to transaxle 48 35
Engine roll restrictor to subframe 48 35
Rear engine mounting to body 48 35
Rear engine mounting (nut on transmission mounting bracket) 133 98
Front engine mounting to engine 80 59
Front engine mounting to body 48 35
Wheel nuts 128 94
Suspension strut to body 48 35
Lower suspension arm ball joint to spindle carrier 47 35
Power steering pump 23 17
Power steering pump pulley 47 35
Cylinder head boltsa
Timing belt tensioner 25 18
Spark plugs 15 11
Oil level indicator tube 10 89
Valve cover bolts 9 80
Ignition coil (EI) bracket to cylinder head 10 89
Rocker arms 25 18
Camshaft thrust plate bolts 10 89
Camshaft pulley bolt 105 77
Camshaft position sensor (CMP) 25 18
Oil pressure switch 13 10
Oil pump 13 10
Oil pump tube 10 89
Coolant pump 25 18
Oil intake pipe to oil pump 10 89
Main bearing bolts 99 73
Rear crankshaft oil seal retainer 25 18
Big end bearing cap nuts (stage 1) 38 28
Intermediate shaft bracket 48 35
Oil pan to crankcase 25 18
Oil pan baffle 25 18
Upper timing belt cover 48 35
Lower timing belt cover 10 89
Upper strut mount nuts 30 22
Engine oil drain plug 25 18
Knock sensor 20 15
Flywheel 82 60
Crankshaft position sensor 6 53
Crankshaft pulley 120 89
Battery tray 25 18
a refer to the procedure in this section
Second is the Zetec cars:
Engine Data Description 2.0L DOHC 16V
Engine management EEC V/SEFI
Emission standard 96 EEC
Fuel 91 RON unleaded
Identification code CAA
Bore 84.8 mm
Stroke 88.0 mm
Cubic capacity 1,988 cm3
Compression ratio 9.6:1
Maximum engine performance at 5,300 rpm 130 hp
Maximum engine torque at 4,000 rpm 130 lb ft
Idle speed rpm 800 rpm
Speed limitation (rev/min) 7,100 rpm
Engine Oil Viscosity/ambient temperature Description Specification
Recommended engine oils
SAE 5W-20/below -30C to over +40C SAE 5W-20 Engine Oil certified for gasoline engines by the American Petroleum Institute ILSAC GF-3 and WSS-M2C153-H
SAE 5W-20/below -30C to over +40C Ford Formula E Economy Engine Oil ACEA A1/B1 and WSS-M2C914-A
If engine oils of this specification are not available, engine oils of specification API SH/EC, ACEA A2/B2 or ACEA A3/B3 may also be used.
Capacities Description Liters
Engine oil, initial fill including filter 4.35
Engine oil, oil change including filter 4.25
Engine oil, oil change excluding filter 3.75
Lubricants, Fluids, Sealers and Adhesives Item Specification
Sealant, camshaft bearing caps WSK-M2G348-A5
Sealant, cylinder block mating faces (Hylosil 502) WSK-M4G320-A
Sealant, cylinder block mating faces (Loctite Ultrablack) (alternative) WSE-M4G320-A2
Sealant, crankshaft position sensor ESW-1C155-A
Sealant, crankshaft position sensor (alternative) WSD-M1C-226-A
Sealant, oil pan WSE-M4G323-A6
Thread locking compound SDM-M4G9107-A
Spark plug thread lubricant (Never Seeze) WSD-M13P8-A1
Lubricant, injection nozzle O-rings WSEM-2C903-A1
Silicone grease for spark plug connector seal A696-M1C171-AA
High-temperature grease for clutch disc engagement splines ESD-M1C220-A
Cylinder Block Description mm
Cylinder bore diameter, class 1 84.800-84.810
Cylinder bore diameter, class 2 84.810-84.820
Cylinder bore diameter, class 3 84.820-84.830
Inner diameter, main bearing shells installed 58.011-58.038
Inner diameter, main bearing shells installed (main bearing shells with stepped sizes) 58.008-58.031
Main bearing radial clearance 0.011-0.058
Main bearing radial clearance (main bearing shells with stepped sizes) 0.020-0.042
Main bearing parent bore 62.287-62.300
Pistons Description mm
Piston diameter, class 1. 84.770-84.780
Piston diameter, class 2. 84.780-84.790
Piston diameter, class 3. 84.790-84.800
Piston clearance in cylinder 0.010-0.030
Piston ring gaps (installed) a
Upper compression ring 0.30-0.50
Lower compression ring 0.30-0.50
Oil scraper ring 0.40-1.40
a The piston ring gaps must be distributed evenly around the circumference of the piston This also applies to the oil scraper ring elements. Align the ring gaps at 120 degrees to each other.
Crankshaft Description mm
Main bearing journal diameter 57.980-58.000
Crankshaft end play 0.09-0.26
Connecting rod bearing journal diameter 46.89-46.91
Lower Crankshaft Spacer Description mm
Required spacer washer thickness if there is a gap between the cylinder block and the lower crankcase of:
0.26 mm-0.50 mm 0.25
0.51 mm-0.75 mm 0.50
Connecting Rod Description mm
Big end bore diameter 49.89-49.91
Small end bore diameter 19.951- 19.981
Inner diameter, connecting rod bearing shells installed 46.926- 46.960
Radial connecting rod bearing clearance 0.016-0.070
Axial connecting rod bearing clearance 0.090-0.320
Piston Pin Description mm
Piston pin length 55.800- 56.200
Piston pin diameter, white 19.997- 20.000
Piston pin diameter, red 20.625- 20.628
Piston pin clearance in piston 0.016-0.049
Camshaft Description mm
Bearing journal diameter 25.960- 25.980
Camshaft bearing radial clearance 0.020-0.070
Camshaft end float 0.080-0.220
Lobe lift intake 8.90
Lobe lift exhaust 8.70
Theoretical valve maximum lift intake 8.90
Theoretical valve maximum lift exhaust 8.70
Valves Description mm
Valve clearance in the valve guide
Intake valve 0.017-0.064
Exhaust valve 0.017-0.064
Intake valve clearance (at 20C 5C) 0.11-0.18
Exhaust valve clearance (at 20C 5C) 0.27-0.34
Cylinder Head Description Specification
Maximum distortion (mating surface) 0.1 mm
Height of mating surface 1.76 mm-2.12 mm
Peak-to-valley height of mating surface (reference length 2.5 mm vertical to groove direction) R 3z = 6.0 μm
Oil pressure at 800-850 rpm 1.3 bar-2.5 bar
Oil pressure at 4000 rpm 3.7 bar-5.5 bar
Hose clamps 4 35
Intake manifold studs 5 44
Intake manifold bolts and nuts 18 13
EGR tube assembly to EGR valve 40 30
EGR pipe to ignition coil bracket 6 53
EGR tube assembly to catalyst 40 30
Heat shield to exhaust manifold 10 89
Exhaust manifold studs 5 44
Exhaust manifold nuts 16 12
Catalytic converter to exhaust manifold 48 35
Catalytic converter to exhaust 47 35
Right-hand driveshaft center bearing 25 18
Generator to bracket 25 18
Generator bracket to upper cylinder block bolts 25 18
Generator bracket to lower cylinder block bolts 65 48
Transmission flange bolts 47 35
Starter motor to transmission 35 26
Oil drain plug, MTX transmission 45 33
Oil control plug, MTX transmission 45 33
Flywheel bolts 112 83
Clutch pressure plate 29 21
Engine roll restrictor to transmission 48 35
Engine rear mount to body 48 35
Engine rear mount (nut on transmission mounting bracket) 133 98
Engine front mount to engine 80 59
Engine front mount to body 48 35
Power steering pump to bracket 24 18
Power steering pump bracket 48 35
Cylinder head bolts a
Camshaft bearing cap boltsa
Cylinder head covera
Spark plugs 15 11
Camshaft timing belt pulleys 68 50
Upper timing belt cover 10 89
Ignition coil (EI) bracket to cylinder head 21 15
Thermostat housing 20 15
Fuel rail 10 89
Engine rear lifting eye 16 12
Engine rear lifting eye studs 6 53
Engine front lifting eye 47 35
Cylinder blocka
Oil pressure switch 27 20
Cylinder block oil gallery blanking plugs 23 17
Heater pipe bracket to oil pan 10 89
Oil pan to lower crankcasea
Lower crankcase to cylinder block 22 16
Oil pump 11 8
Main bearing boltsa
Connecting rod bearing cap boltsa
Coolant pump 18 13
Crankshaft rear oil seal carrier 20 15
Drive belt idler pulley 40 30
Crankcase ventilation pipe bracket 23 17
Crankcase ventilation 10 89
Coolant pump pulley 24 18
Crankshaft belt pulley 115 85
Crankshaft position sensor bracket 21 15
Crankshaft position sensor to bracket 8 71
Idler pulley 23 17
Knock sensor 20 15
I am continuing on another thread for the rest.........
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
