Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Energy Suspension-Motor Mount Insert & Hyper-flex Master Kit
Old 04-13-2007, 10:18 AM   #7
nthcoastcom
nthcoastcom's Avatar
Fan#: 7017
What I Drive: 96 SVT Cobra, 07 GT
Points 6,609, Level 53
Points: 6,609, Level: 53 Points: 6,609, Level: 53 Points: 6,609, Level: 53
Level Up 30% Completed
FF Reputation: 9 nthcoastcom Good Standing Member
Buy-Sell-Trade Rating: (21)
Originally Posted by The Mailman 666 View Post
How much should I expect to pay to have the bushings install here in Canada
You would have to check around to shops that would do the work. I have no idea what it may cost in Canada.
Originally Posted by Sonicbluezx3 View Post
Do these come individually? I've already got a set of the coil spring isolators and rear sway bar bushings, but I'd want the rest. (Rear trailing arm bushings, front control arm bushings, front sway bar bushings, and rear bump stops)
The do come indivudually. I will PM you with the prices.
Originally Posted by WhiteGTDropTop View Post
I am interested in the tourqe mount bushings only. I just have a few questions. Do they work anywhere near as good as the VF dogbone? Also, how hard is the install? thanks
Sean
This works very well for the cost of the part. The biggest problem is all the flex that OE bushings allow. Polyurethane is a very dense hard material to stop most of the flex. My opinion is if you do not want to spend $100.00 for the VF this is a great option
Just as easy as the VF to install, take off your OE mount press the bushings out and put these in. Should less than 30 minutes
nthcoastcom is offline
