Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Repair and restore rims (Surface pitting, chips, curb-rash)
Old 02-19-2007, 01:55 PM   #2
mpcv2000
mpcv2000's Avatar
Fan#: 23629
What I Drive: 01 SE + 1989 RX7
FF Reputation: 19 mpcv2000 Great Standing Member
Very interesting.
To keep this on topic if you don't mine I will add my : how to get rid of the clear coat pealing off and mag lips polishing.
If someone has wheels in that condition :
320 Sand paper :
400 Sand paper :
600/1000 sand paper : note : Wheel on the car still has factory clearcoat ( not done yet )
2000 sand paper : note : Wheel on the car still has factory clearcoat ( not done yet )
2000 again :note : Wheel on the car still has factory clearcoat ( not done yet )
When done with the wet sanding stuff , all you have to do is use any paste to polish aluminum and more you polish better it will get..
You can also fix minor curb rash , I had a few , here's a example..note : I guess you know by now..:)
I used a drill with a san paper wheels to sand down the deep scratches , it can fix some pretty nasty scratch after it will all go away with the wet sanding procedure explained earlier.
Here's a before and after pictures , it is the exact same wheel.
After.. Bah....Note Why not....: Wheel on the car still has factory clearcoat ( not done yet )
It took about 2 hours per wheel and I have 8 wheels like that , I even did the wheels who had no issue with the clear coating , I wanted all of them exactly the same..
Since you're a moderator you can edit or delete my post if you think it doesn't belong in your thread
Martin !
mpcv2000 is offline
