Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tow Truck Bent Tie Rod
Old 02-17-2007, 11:51 AM   #5
rsouth5
Fan#: 43850
What I Drive: 2003 charcoal gray zts
FF Reputation: 1 rsouth5 Good Standing Member
it is possible for tow company to damage but will be very hard to prove. 420 seems very high. I just changed inner tie rod on pass. side part was 23.00 at dealers four wheel alignment is only 100 or less. Did you at any time hit a curb? I hit a curb snow covered at 10mph and it bent it bad. Was your steering wheel out of alignment? I think your mechanic screwed you. You can look at the boot around your tie rod it will have a metal band that is crimped if they replaced the tie rod then it should have a plastic zip tie or maybe a hose clamp. I don't know what the book calls for as far as labor but more than an hour labor is too much. and more than 60.00 for the part is too much. Your bill should have been no more than 250.00
rsouth5 is offline
