Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to maintain your car.
Old 01-18-2007, 06:30 PM   #1
MaximusZTS
MaximusZTS's Avatar
Fan#: 24918
What I Drive: 2002 Infra Red ZTS
FF Reputation: 13 MaximusZTS Great Standing Member
I was asked somequestions of at another site and did a small write up I want to share with you guys. There was a post that a guy made and hi listed his steps on how he detailed a Focus. his step were a bit off and I was tring to help clarify proper useage of the products used.
Originally Posted by MaximusZTS
Are these the steps you are talking about?
Originally Posted by focusownerskid
Thanks for the compliments guys, had a lot of fun getting this car together, she was in rough shape...
As for waxes;
Step 1;
Step 2;
Step 3;
Step 4;
Final coat;
Of course all that began with a nice Mother Clay Bar;
To simplify what he is doing
First he used a really good cleaner wax (People in the know call it #12 or A12, because that is the Meguiar's part number.) It is a really good product. but if you want a show car finish this is not the product for you.
Second he used some DC3 (Deep Crystal step 3) Which is a pure wax. which means it has not cleaners in it at all. It is a really good consumer wax. Because it is a Carnuba wax many professionals would use it as a final coat. but there are better waxes out there. Once again if you want a show car this is not the route I would take.
Third NXT Tech wax is IMO the best consumer wax available. Liquid or paste you can not go wrong. Many professionals would say that useing a Synthetic wax such as NXT on top of a Carnuba wax is not the best idea. Synthetic waxes are formulated to bond to paint not wax, and truth be told because it is a full synthetic "wax" it actually does not contain wax like the DC3 does. Therefore you have bonding issues. It is considered a Paint Sealant.
Fourth #7 Show Car Glaze is a wonderful pure polish. You want a show car, this is a must have to bring out the beauty and depth of gloss in you cars finish. However you would put this on before you applied any wax. It does not have any cleaning or protecting properties at all. It is a very oil rich product and those oils need to be worked into the paint surface, not on top of a wax.
Final Coat #26 Yellow wax is a very good strong wax. but as far as looks go it is not the best and most likly undid a lot of the previous waxes.
Now appling 4 waxes and a pure polish is a bit of an overkill. Odds are that the #7 did not penitrate the wax surface and not much was left behind. the #26 rubbed off most if not all of the NXT and the NXT rubbed off most of the DC3 because NXT does contain a chemical cleaner. Two thin coats of wax is all that is needed, and maybe a pure polish before like #7 depending on how much time you want to spend waxing your car.
Clay bar Is a must before you do any waxing or polishing. It will remove any "Above surface" contaminates. Such as fallout, paint overspray, tree sap, etc... So for sure, after you wash you want to clay.
There are 5 steps to making you car shine.
First Wash your car, dont scrub on it, just wash it really well using a PH balanced car soap. My fav is Gold Class Car Wash Shampoo & Conditioner
Second Clean or surface prep. here you will use the clay bar to remove any "Above surface" contaminates. I would reccomend Quik Clay System
Third Polish This is where you use a cleaner polish like ScratchX to remove "Below Surface" Contaminates. Such as Swirls, light scrathes, bird dropping etching, etc... Then you can apply a pure polish like #7.
ScratchX
M-07 Show Car Glaze
OR
Deep Crystal Polish
Fourth Protect this is where you will apply your waxes. Here I would use some NXT tech Wax. Apply one thin coat, let hase, and buff off. Then apply a second coat and repeat. Applying any more coats of wax will not do any good. You will just be buffing off previous coats as you apply new coats. the only real reason you need two coats to begin with is so that you can make sure you covered all you paint. You may have missed a spot of the wax was applied thin in one area. The second coat will help ensure you have a good soild coverage.
NXT Generation Tech Wax
Fifth Maintain Now that you have done all this work make sure it stays looking good. here is where you will use your spray waxes and quick detailer (QD) products. QD will remove any light dust and or finger prints off of your flawless finish. It is not a substitute for a wash however. Spray waxes will keep you base wax looking good and make you base wax last longer.
NXT Generation Spray Wax
Quik Detailer
Oh I almost forgot step 6.
Sixth Enjoy Take you car to a car show or just drive around and know you car looks better than 95% of the cars on the road. It is really great if you do this right after a rain adn you car is really outshining everything else.
Ask if you have any questions. Shawn.
ZETEC Crew #2.0
If you are looking for a quailty Auto Detailer in the So Cal Area please view my profile.
MaximusZTS is offline
