Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Nitrous Questions..read here first.
Old 12-01-2006, 11:47 PM   #148
Scott_SVT
Scott_SVT's Avatar
Fan#: 21836
What I Drive: 2002 Pitch Black w/Blue int SVT
FF Reputation: 4 Scott_SVT Good Standing Member
unless you have a raised rev limiter(as in, tune), 7200 is a deadly place to go with the window switch, it wouldn't be a good thing for the stock rev limiter to kick in at the same time at the window switch kicks off, no time for the intake to clear...
I run mine on at 4000 and off at 7000, but I have my rev limiter set to 7600, so there is plenty of room .
3000 rpm is a little low to start off... most guys launch at higher rpm's than that, but you can play around with it and see what works best for you. I would recomend not going any lower than that.
If you set it at 6800, you need to shift at 6700 or so... there is no point driving thru the off cycle, its only there for your engine's protection.
13.746 @ 100.52mph
SVT SQUAD #8
Hurray!! a Squad! how umm... stupid....
Scott_SVT is offline
