Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of rear hatch trim?
Old 03-29-2004, 05:45 PM   #5
blackandgold
blackandgold's Avatar
Fan#: 495
What I Drive: 2008 VW GTI 2006 Ford Explorer LTD
Points 18,644, Level 86
Points: 18,644, Level: 86 Points: 18,644, Level: 86 Points: 18,644, Level: 86
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 1 blackandgold Good Standing Member
Originally posted by bak9799
To remove the rear hatch you neeed to open the hatch. Remove the 4 push tabs(plastic) then take off the door panel. Once the door panel is removed, you'll need to take off the wiper motor so you can get to the bolts that hold the trim piece on. You can let the motor hang you won't do any damage to it.
After then you can remove the 4 bolts that hold the trim piece on.
Put back together in the reverse order.
Hope that helps
That is exactly what i did to get my chrome trim on good walk thru bak!!
ae86
Originally posted by focusfreak03
^ what the hell is that supposed to mean, you quote me and then put down some american eagle sh**
blackandgold is offline
