Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - removal of rear hatch trim?
Old 03-29-2004, 05:17 PM   #4
bak9799
bak9799's Avatar
Fan#: 2170
What I Drive: 2000 Focus ZX3, Pitch Black
FF Reputation: 1 bak9799 Good Standing Member
To remove the rear hatch you neeed to open the hatch. Remove the 4 push tabs(plastic) then take off the door panel. Once the door panel is removed, you'll need to take off the wiper motor so you can get to the bolts that hold the trim piece on. You can let the motor hang you won't do any damage to it.
After then you can remove the 4 bolts that hold the trim piece on.
Put back together in the reverse order.
Hope that helps
bak9799 is offline
