Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A video of my new motor
Old 10-02-2006, 02:03 PM   #1
DJ Sures
Fan#: 4128
What I Drive: Boost
FF Reputation: 1 DJ Sures Good Standing Member
http://video.google.ca/videoplay?doc...1&q=atomic%27s
The car... 2002 SVT Focus
Rear view
Side view
Front Angle
Engine being built
Engine
Ball bearing big turbo :)
Intercooler
Beautiful Aluminum welds by Mike from Lightspeed
Dash 1
Dash 2
Microsoft Media Center IR Receiver
Rear hatch
Round Two
I choose to turbo charge this new motor to make more power and quiet the exhaust over my last version. Both requirements have passed expectation. Everything you see here in this build is entirely custom and one of a kind. Fitting such a large turbo was a challenge, but as you can see.... I did it :)
Engine Modifications (360 HP)
- Motor originally built 01-28-2004, rebuilt 08-05-2006
- Forge BOV
- 55 lbs/Hr Fuel Injectors
- Garret GT28R-400 HP Ball Bearing Turbo .70 A/R
- Tial 38mm 7.5 PSI Wastegate with divorced outlet
- Custom log style turbo manifold with T25 outlet
- Profec B Boost Controller
- Welded Custom aluminum intercooler piping
- Spearco front mount intercooler mounte and cut into frame (Size: big)
- 66 mm throttle body
- Motor rebuilt with new internals and larger ring gaps for heat expansion
- Fidenza Adjustable Exhuast Cam Gear
- Fidenza Aluminum Fly Wheel
- 3" Custom Turboback Magnaflow exhaust with removed cat
- K&N Air Filter
- Greddy oil catch can
- Stant 180F/82C Thermostat
- Stock clutch
- AZFS22C 1 Step colder sparkplugs
- Removed Air Conditioning to fit turbo
- 76mm MAF
- Relocated IAT by BOV to read compressed air charge
- Many custom flanges, piping and fittings.
Interior Modifications
- Dash (sonic blue)
- Speaker grills (gun metal)
- Vents (sonic blue)
- Gauge Bezel (sonic blue)
- Ash Tray (gun metal)
- Custom diamond plated alimunum floor mats (front and rear)
- Custom fiberglass LCD/sunroof control panel
- Under dash low profile blue neon lighting
- Removed 2/3 of Back Seat replaced with custom sealed subbox and toolbox
- Blue interior LED replacements
- XENON interior lights swap
In Car Entertainment Modifications
- Sony CDX M750 Head Unit mounted in glove box
- Sony 10" Xplode sub in custom 12 litre sealed fiberglass/MDF box
- Custom 12 litre sealed box and toolbox replaces 2/3 of rear seat
- Sony XA-300 Input Controller Hub with USB Port
- Sony BUS connectivity
- Sony XM-502x Sub Amp
- Alpine SPS-5729 Speakers
- Celeron 1.6ghz mini PC (MCE, Bluetooth, 802.11) drawing only 60 Watts
- 3" LCD Screen custom fitted on dashboard
- 3" LCD Screen in custom fixture on ceiling
- Audio fed by USB Digitally to amplifier via Sony XA-300
Suspension Modifications
- Eibach Sportline Springs
- 17" Core Racing gunmetal wheels
- 215/40R17 AS Kumo's
Exterior Modifications
- Billet Fuel Door - gunmetal grey
- Projection Headlights with halo - sonic blue
- Shortened Antenna
- Front Lower Grill - gunmetal grey
- Front Lower Lip - sonic blue
- Front Upper Grill - sonic blue
- Rear Trim - sonic blue
- Rear Lower Grill - gunmetal grey
- Tinted Windows
- Ford Racing Rear Clear Tail Lights - custom coated in black vynl
- Spark plug cover - sonic blue
- Coolant cover - sonic blue
- Wings West Urethane Avenger Side Skirts - sonic blue
Electronics Modifications
- WMS Wideband and Data Logger
- Motormaster 200W digital invertor for PC wired to remote relay
- Greddy Electronic Profect B Boost Controller
- Autometer boost gauge
- Autometer electronic fuel pressure gauge
- Autometer 3 guage A-Pillar pod
- Apexi: turbo timer, air/fuel, voltage
- Relocated Battery in rear w/brass fittings, welded connectors & grounds every 12"
- Custom Tuned with Diablo Predator
DJ Sures is offline
