If anyone is not sure about switching to RP, DO IT. Ever since I got my SVTF, I've noticed the tranny is a bit "knotchy", it seemed like it needed a little too much force to get into gear.
At my last oil change, 27,000 I asked my mechanic to swap it out and the difference is very noticable. Gear changes are easier now, much smoother and faster.
It's one of those "little" things you can do for your SVTF that you will notice and enjoy.
The stuff isn't free (~$11(US)/quart) but my mechanic said that my old fluid was pretty grotty so it was time to change.
I am seriously thinking about doing this - this weekend perhaps. The "notchy" feeling I have mixed emotions about, esp after taking that weight off the linkage...seems like its a little more pronounced. I know I am due for a change, so what the hell.
which bottle did you dump in there and how many bottles did it take?
$11-18??? I paid $7 a quart for sychromax at a local store. The shifter is smoother though with it, but I replaced the clutch/flywheel, added sychromax, and took off the shifter counterweight off all at the same time.
It takes 2 bottles of sychromax, you'll need this pump thing my dad had to get it into the tranny easily
I am wanting to do the same thing and replace my tranny fluid with royal purple. I am hearing a lot of good things about it. But I cannot find this stuff, (synchromax) where are you guys getting this stuff???
Also you are talking about counter shift weights, and am not that good with tranny's but what are those and what do they do? I know where they are but I thought if you take those you can slip out of gear really easily??
you dont need any special pumps or anything. only a 8mm allen socket. the case takes 2.1 quarts. so unfortunately you should buy 3 quarts. i got mine for @7.95/q
My mechanic said it's supposed to be changed at 120,000 BUT he said my fluid was pretty foul at 27,000 so, just to be safe, I'll probably do it every 30,000. Especially when you consider a new Getrag is going to run you $3,500(US$).
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
