Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2000-2004 Ford Focus Rear Tire Wear
Old 09-28-2006, 05:10 PM   #14
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
^^^Because a "perfect" reading shop-wise is a reading within spec.
As you can plainly see, that spec is allowed to go a long ways towards the negative side.
And, -2.3° is a boatload of camber out back, yet is "perfect" because it's within spec.
Did they give you a print out after the alignment so you can tell where you're at?
Really, unless you're racing, -1° in the back is as much as you'll ever need, and will certainly help with the inner tire wear problems.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
