Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Swap in Tilt Steering Column/Replace Clockspring.
Old 09-28-2006, 05:56 AM   #1
dchoward1977
dchoward1977's Avatar
Fan#: 16096
What I Drive: 2000 Cloud 9 White Focus LX sedan
FF Reputation: 1 dchoward1977 Good Standing Member
DISCLAIMER: You will be working with the SRS (Airbag) System during this procedure. I won't be held responsible if you hurt yorself, someone else or your Focus doing this. PROCEED AT YOUR OWN RISK!!! That said, if you're conscientious and careful and know your car, you'll have no problems doing this. If you don't feel comfortable with it, don't even try.
I made this HOW-TO to show how easy it is to swap in a Tilt and Telescope steering column into your Focus. If you're like me and didn't have it, I highly recommend snagging one from your local junkyard. Makes a huge difference in driver comfort, I'm now able to sit a good 3 inches further back from the pedals, avoiding the so-called "Monkey Driving Position". Now I'm much closer to legs straight, arms bent rather than the other way around. As close as possible in a Focus anyway. Also I'll cover getting the clockspring out, in case anyone's is broken.
Tools Needed:
A good socket set
A T-15 Torx bit
A T-40 Torx bit
Go out and disconnect your battery while you get your tools ready. Wait a good 10 minutes to make sure the SRS (airbag) system discharges. I sure don't want an airbag blowing up in my face, and neither do you.
More Ideas Than Money
"My third gear went out. I put a new one in but the car didn't like it so it didn't use it."--My idiot neighbor
dchoward1977 is offline
