Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Autocross pivots or 360's;what are your proven techniques?
Old 09-26-2006, 06:15 PM   #2
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
This is a tough one to explain.
1st off, forget the E-Brake method.
For a tight 180, I brake right at the threshold (ABS kicking in), and at the split second before turning in,
shift to 1st, turn the car, and gently roll back on the gas so the inside front tire doesn't spin.
I also come in wide, and go out narrow.
See...Late Apex...>>> http://www.eurotuner.com/howto/38238
Scroll down to "The Line", it's explained there with Figure B being the proper line.
360...
Haven't had any of those, unless you consider our "skid pad" at a test and tune to be one.
Hint...adjusting the steering wheel is costing you time.
Hold the wheel steady, and adjust the line of the car with the throttle.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
