Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help build the ultimate STS Focus autocross racer
Old 08-31-2006, 05:06 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
UDP: N?A
Allowed:
14.10 ENGINE
G. Any accessory pulleys and belts of the same type (e.g., V-belt,serpentine) as standard may be used.
This allowance applies toaccessory pulleys only (e.g., alternator, water pump, powersteering pump, and crankshaft drive pulleys).
It does not allow replacement, modification, or substitution of pulleys, cogs,gears, or belts which are part of cam, layshaft, or ignition drive or timing systems, etc.
Any crankshaft damper or pulley may be used.
SFI-rated dampers are recommended.
Supercharged cars may not change the effective diameter of any pulley whichdrives the supercharger.
Battery relocation: Maybe (can't remember if its allowed)
Allowed:
14.9 ELECTRICAL SYSTEM
The make, model number, and size of the battery may be changedbut not its voltage.
Relocation of the battery or batteries is permitted but not into the passenger compartment.
If the battery is relocated and the original battery tray can be removed by simply unbolting it,
the tray may be removed, or relocated with the battery.
Holes may be drilled for mounting or passage of cables.
Longer cables may be substituted to permit relocation.
The number of battery or batteries may not be changed from stock.
The area behind the rearmost seat is not considered to be within the passenger compartment.
Seats: Corbeau (can't remember if fixed-back is allowed)
Allowed, with exceptions:
14.2 BODY WORK
B. The driver and front passenger seats may be replaced, with the following restrictions:
The seating surface must be fully upholstered.
The top of the seat, or an attached headrest, may not be below the center of the driverís head.
The seat, not including mounting hardware, must weigh at least 15 pounds.
^^^Nothing about fixed back, which means it's probably not allowed.
Motor mounts: Stock (IIRC, rear mount is STX)
Allowed...all 3 of em:
14.10 ENGINE
H. Engine mounts may be replaced, but must attach in the factory location(s) without additional modification or changes.
Engine position may not be changed.
The volume of metal in a replacement mount may not be increased relative to the volume of metal found in a stock mount for the particular application.
Solid metal mounts are specifically prohibited.
Any non-metallic inserts may be used.
So, there ya go.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
