Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help build the ultimate STS Focus autocross racer
Old 08-31-2006, 12:40 PM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
Points 11,256, Level 70
Points: 11,256, Level: 70 Points: 11,256, Level: 70 Points: 11,256, Level: 70
Level Up 2% Completed
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Buy-Sell-Trade Rating: (3)
2.3l Duratec Focus ST w/ 5-speed
Engine
Air intake: Marcy Motorsport CAI
Exhaust: Borla 2.5"
UDP: N/A
Tune: SCT Flash
Ignition: N/A
Suspension
Springs: Koni Coilovers w/ 300#F, 350#R springs
Struts: Koni Coilovers
Sway Bars: H&R front and rear, front set on lowest setting
Camber Adjustment: LCR race camber plates
Brakes
Rotors: OEM
Pads: Hawk HP+
Lines: Russell Stainless Steel
Wheels
Brand: Rota or similiar
Spacers: No
Tires
Brand: Falken Azenis RT-615
Miscellaneous
Battery relocation: Maybe (can't remember if its allowed)
Seats: Corbeau (can't remember if fixed-back is allowed)
Strut Brace: I'll pass, but FC bar will work
Shifter: Steeda Tri-Ax
Motor mounts: Stock (IIRC, rear mount is STX)
Setup
Front camber: Max negative
Front toe: 1/8" out total
Rear camber: -1*
Rear toe: 0"
Front tire pressure: Depends on course
Rear tire pressure: Depends on course
I went with the ST instead of the 03-04 ZX3 because it comes with a 3.82 gear from the factory, and there isn't much of a weight difference between the two. Only downside is loading and unloading gear at the event.
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH - SOLD
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
2016 Ford Fusion Hybrid
Egz is offline
