Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - alignment specs for autocross
Old 08-29-2006, 01:19 PM   #9
Carrera26's Avatar
Fan#: 12237
What I Drive: 2005 Mazda3 2.3/2003 VW Passat GLX
FF Reputation: 2 Carrera26 Good Standing Member
My reccomendation;
Front - Full Stiff
Rears - 50%-80% Stiff
Front - 1 degree negative
Rear - 0 / .5 degree negative
Front - 1/16 - 1/8 toe out
Rear - 0 Toe
Front - Max Grip for your tires (measured with pyrometer or shoe polish)
Rear - 4 PSI less than front
Use your rear PSI to fine-tune the setup. If there's something that feels just a bit off, add or subtract a couple pounds in the rear as needed. Most of it's actually finding the most neutral place that you can and then adjusting your driving style to maximize it.
Good luck!
Don't waste another minute waiting on parts, or anything else. Just get out there and start racing! You will suck at first, and you will be slower than many other cars, but the only thing you will regret is not starting earlier...
Carrera26 is offline
