Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Long Crank/Hard Start 2.0L And 2.3L Engine With MTX-75 Transaxle Bulletin
Old 08-22-2006, 06:59 PM   #71
shawn_carter69's Avatar
Fan#: 37668
What I Drive: 2006 Infra Red ZX4 ST
FF Reputation: 1 shawn_carter69 Good Standing Member
Originally posted by RedDevilST
So wouldn't this long cranking problem, mine does it too just I just leave the ignition in pos 2 for a few seconds before starting, cause starters to fail prematurely?
I can't see how. You're not actually cranking the starter over, and pos 2 (if you mean the second click) is where the key sits during normal operation anyways. If you mean the second position as in the first click then it's just accessory power.
ST Crew #48
shawn_carter69 is offline
