Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Update on Headers...
Old 08-03-2006, 01:02 PM   #16
phord_phocus86
phord_phocus86's Avatar
Fan#: 33505
What I Drive: 2002 ZX3 Base
Points 11,838, Level 71
Points: 11,838, Level: 71 Points: 11,838, Level: 71 Points: 11,838, Level: 71
Level Up 47% Completed
Level up: 47% Level up: 47% Level up: 47%
FF Reputation: 3 phord_phocus86 Good Standing Member
Buy-Sell-Trade Rating: (12)
Originally posted by Dubz
For firing order, you do not want to group the two firing together at the same time until as late as possible.
This would GREATLY reduce flow, as you have 2 times as much air trying to pass through the same size pipe. If they join up further downstream they will have cooled an amount and therefore will require less volume. also i belive that the flow past the other primary tube creates a vaccum which helps scavange exhaust gasses.
well if you think about it, its a chain reaction 1 and 3 don't fire at the same time, it's 1 then 3 so you have fire#1 working its way down with fire #3 right behind it giving it an extra push.
I still have a Focus parked, I might fix it up one day.
phord_phocus86 is offline
