Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - :: Cracked Thermostat Housing Assembly ::
Old 07-09-2006, 07:23 PM   #1
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: SVT
Points 16,874, Level 83
Points: 16,874, Level: 83 Points: 16,874, Level: 83 Points: 16,874, Level: 83
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
I have seen a few threads about this but no pics...In short, our notoriously leaky valve cover gaskets seep oil and it gets between the block and Thermostat Housing this causes the Oring to swell and sometimes crack the plastic.
Just thought I would show you a pic of what that is exactly...I just dealt with this today...good thing I bought the housing assembly as well.
As you can see the one on the left is the bad one. The ring swelled and did crack the pastic that surrounded it.
The repair went really easy. Just drain the coolant, unhook the hoses and take three bolts outta the side of the housing to remove it from the side of the block.
On the front of it is another plastic piece held in place with three screws (and some mysterious chunk of metal on two of them). Just unscrew them and pop it off...you will find your thermostat inside:
You will need to swap that over to your other housing, but check to make sure the rubber seal around it is in good shape. You might just want to go ahead and replace it while you are at it...its pretty cheap but you will have to buy the thermostat and rubber gasket around the edge seperately. ALSO, be sure to pay attention to the little air vent hole in the top of the thermostat and its position as its seated within the housing. You basically want it at the top, so it can let air breathe out.
Two other things you are going to want to swap/check are the sensor in the top:
and the ridiculous plug on the bottom:
As you can see they have little metal clips which hold them in place. Just grab it with a pair of needle nose and pull it off, then you can pull the part from the housing.
**Note** I pulled my silver "plug" and put it into the new housing...the Oring on it was crapped out and when I started my car, it began to leak. So you may want to look into getting one as backup as well as a new sensor. They both have Orings on them that could easily get toasted by the heat and chemicals. In the dealers exploded diagram, it showed a second sensor going to where the plug was, I am guessing that they use this housing on other cars and just plugged that hole up. Just keep it in mind and use the part number I listed below if you need to replace it.
All in all, super easy to do. Should take you about an hour and a half....basic blot off/bolt on operation.
Hope this helps some of you if you are thinking about doing the repair yourself. Its simple and cheaper than letting the dealer do it.
**UPDATE** Here are some part numbers for you (SVT)
Thermostat Housing Assembly - XS7Z-8592-AD (roughly 68 bucks and it includes a rubber gasket)
Sender Asy (sensor on top of assembly) - XS6Z-12A648-CA ($19)
Silver Plug - 2M5Z-12A648-AA ($15)
Thermostat- F8RZ-8575CA ($10)
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is offline
