Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Front strut tower bar install with aem cai SUCCES!!!!!!!
Old 03-13-2004, 03:54 PM   #1
breakdancein
Fan#: 78
What I Drive: 03 svtf
FF Reputation: 1 breakdancein Good Standing Member
i did it!! i installed the focus central front strut tower brace with my aem cai. i had to get a little creative but ill explain how i did ti so u guys who want one can do it also
1. jack up car so tires just barely lift off the ground this equalizes the struts.
2. remove fuse box cover ( the 1/4 of an inch that the lip takes up will make u not be bale to install the strut bar.
3. lossen up hose clamp holding cai tube into connector to throttle body and slide the tube out fromt he connectore slightly ( the cai tube should be about onyl 1/4 inch into the sleeve that conencts to the throttle body rather than the normal 1/2 inch or so. this wont affect cai at all and again that 1/4 of an inch will be crucial.
4. starting with the drivers side put the brace onto the bolts then do same with passenger side ( the strust brace bar should be just touching your cai).
5. tighten bar down to 18lb/ft like directed in instructions and put fuse box cover back on. it might take a little elbow greese but ti will fit
ok here comes the problem. since the strut tower brace is barely touchign the cai when the car take a turn the bar will rub on the cai also at high revs the bar will rub against the cai. after time that rubbign will wear down the metal on both things and also makes a slight rattle.
here is how u fix that. get a rubber hose about 5-6 inches in length( u want about an inch of extra room on both sides form were the cai comes in contact with the strut bar) as thin as possible and big enough aroud to wrap most of the way around the strut bar. splice the hose open so u can wrap it around the strut bar. slide the hose in between the bar and cai( might need a little spit as lube to get it between) then wrap it around the strut bar. secure on both sides with hose clamps as tight as possible.
whalla u have a frotn strut tower bar with a aem cai. i tested the rubber peice to see if it iwll move under hard cornering and drivign and it wont budge. i have an auto-x tommmorow so that will be the true test but i knwo ti will be fine. the thing u can only tell with time is if that rubber will wear through. ill let u know if i see any change as i drive it. hope this helped.
breakdancein is offline
