Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - water pump problems
Old 06-25-2006, 10:54 AM   #2
ztecpower
ztecpower's Avatar
Fan#: 20083
What I Drive: 2002 Infra-red Ford Focus ZTS-S2
Points 16,693, Level 82
Points: 16,693, Level: 82 Points: 16,693, Level: 82 Points: 16,693, Level: 82
Level Up 69% Completed
Level up: 69% Level up: 69% Level up: 69%
FF Reputation: 5 ztecpower Good Standing Member
go here = How - To Set DOHC Cam Timing (Please Make Sticky!! )
THat's the timing how-to I submitted, Thwater pump is easy to remove once you do the above procedure in the link, Remove the water pump pulley by removing the 3 bolts holding it on, then remove timing components to gain acess to the Water pump, which is held in by 4 bolts and a rubber gasket/seal. If your replacing your water pump then you should do a timing belt as a precaution. And if your loosing coolant check the tank, sometimes they crack and only release coolant when they get hot (expand and release coolant in small amounts)
Let me know if you need anything else.
Troy.
AEM Cam Gears, AEM CAI, SCT SF3 (Canned tune) and an exhaust = 114 WHP / 117 WTQ
ztecpower is offline
