Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Making an Ashtray Switch Panel (for neons, LEDs, and whatever else)
Old 05-30-2006, 09:16 PM   #1
OrangeSVTguy
WhiteSTguy
OrangeSVTguy's Avatar
Fan#: 33384
What I Drive: '13 Focus ST White ST3
Points 81,670, Level 100
Points: 81,670, Level: 100 Points: 81,670, Level: 100 Points: 81,670, Level: 100
Forum Activity 4%
FF Reputation: 46 OrangeSVTguy Great Standing Member
Buy-Sell-Trade Rating: (17)
this is my first "HOW TO" so i hope i do this right...
This how to make an Ashtray Switch Panel to control your Neons, LEDs, Fog Lights, and whatever else that could be controlled with a switch. This mounts in your 00-04 factory pull out ashtray. Only minor modifications will be required to install this switch panel and are completly reversable.
I am a sheet metal worker so I have all the tools required to make this job easier and also have access to the metal very easlly. I also linked pictures of the tools/materials below to keep this page as small as possible for the 56k users so be sure to click them if you don't know what they are.
What you will need:
26 gauge sheet metal 6-3/4" x 4-3/4" (find at home depot etc...)
4 - On/Off switches (can be lighted)
12 ga. wire
14 ga. wire
spray paint (color of your choice)
hot glue gun
ruler
sharpie permanent marker (or scratch awl)
inline fuse holder or add-a-circuit
drill
Reamer Drill Bit (Picture)
tin snips (rights and straights)
tongs (folding bar)
Pics of Tools (tin snips, tongs, scratch awl)
to disassemble the ashtray, pop off the top spring plate. next turn it over and take a small screwdriver and pop out the small block tabs through the little square holes to remove the block in the front.
first take your piece of sheet metal, measure and draw lines as follows
you'll notice how one side is shorter then the other, this is because one side of the ashtray is taller then the other. that way the tray should slide in easily without the switches catching onto anything.
cut out using the straight tin snips
fold in a 1/2" all the way around using your tongs
next fold the remaining 3 sides in all about 85* angle. it will seat in the ashtray a whole lot nicer and easier.
measure your switches and then center them up on your cover.
(the mounting holes for mine were 13/16" so I measured 5/8" from the sides to center of hole and then 3/4" from the front to center of hole. then measure 1-3/8" center to center of holes for the front to back one.) using the reamer drill bit, drill out the holes for your switches
next you can spray paint the cover the color of your choice and then let dry for a few hours.
then snap switches into the holes. using a hot glue gun, glue the switches from underneath to keep them from turning.
here are some of the ones i made for other users on FF.com
I'll come back and edit this so I can show you how to wire it up.
Lee
SVT Squad #227 || Build # 1329 of 1978 || FF ROTM Oct. 2006
2004 Comp. Orange SVT 3dr. (Old)
2013 Focus ST White ST3 (Current)
OrangeSVTguy is offline
