Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" Relocating battery to old airbox location
Old 05-12-2006, 09:04 AM   #9
FORDSVTPARTS
FORDSVTPARTS's Avatar
Fan#: 26008
What I Drive: 2002 SVT FOCUS
FF Reputation: 4 FORDSVTPARTS Good Standing Member
Originally posted by HTPerformance
Just rotate the battery 180 degrees and then the power leads will not be in the way.
The way it sits now the battery is positioned exactly as it is in Duratec powered Foci, same height, same terminal location.
If you turn the battery 180 degrees then your positive and negative posts are in the wrong place and I don't think the cables will reach.
You could buy the same group size battery with reversed terminals but I am not sure about the clearance to the hood with the battery pointing in that direction.
FORDSVTPARTS is offline
