Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 ZX3 w/Hard Start Problem
Old 04-26-2006, 05:47 PM   #8
abilath
Fan#: 34575
What I Drive: 2005 Screaming Yellow ZX3
FF Reputation: 1 abilath Good Standing Member
Andy04180:
I don't know if this will help you or not, considering that you have an '06 ZX5, but below are the TSBs associated with my '05 ZX3's hard start problem:
2005 FOCUS: LONG CRANK/HARD START - 2.0L AND 2.3L ENGINE WITH MTX-75 TRANSAXLE
SOME 2005 FOCUS VEHICLES EQUIPPED WITH MTX-75 MANUAL TRANSAXLES, MAY EXHIBIT A LONG CRANK OR HARD START CONDITION WITH NO MALFUNCTION INDICATOR LAMP (MIL) AND NO DIAGNOSTIC TROUBLE CODES (DTC'S) PRESENT. REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) TO THE LATEST LEVEL USING WDS RELEASE B36.12 AND HIGHER OR B37.3 AND HIGHER. THIS NEW CALIBRATION IS NOT INCLUDED IN THE B37 CD. CALIBRATION FILES MAY ALSO BE OBTAINED AT WWW.MOTORCRAFT.COM.
See TSB for complete details
EFFECTIVE DATE: 04/29/2005
18157 2005 FOCUS - CRANK NO START OR OTHER DRIVEABILITY CONCERNS - SERVICE TIP
SOME 2005 FOCUS VEHICLES MAY EXHIBIT A CRANK NO START CONDITION OR OTHER DRIVEABILITY RELATED CONCERNS. PRIOR TO PERFORMING NORMAL DIAGNOSTICS, FIRST CHECK GROUND G301, WHICH IS LOCATED UNDER THE RIGHT REAR SEAT. IF G301 IS OK, PROCEED WITH NORMAL PC/ED MANUAL DIAGNOSTICS.
EFFECTIVE DATE: 09/15/2004
19126 2005-2006 FOCUS - INTERMITTENT LONG CRANK TIMES
SOME 2005 FOCUS (MTX-75 TRANSMISSIONS WITH THE LATEST CALIBRATION PER TSB 05-9-16) OR 2006 FOCUS VEHICLES (ALL TRANSMISSIONS) MAY EXHIBIT INTERMITTENT LONG CRANK TIMES (UP TO 5 SECONDS) ON INITIAL START WITH NO MALFUNCTION INDICATOR LAMP (MIL) AND NO DIAGNOSTIC TROUBLE CODES (DTC'S) PRESENT. THIS IS NORMAL OPERATION AND NO REPAIR IS RECOMMENDED. FAILURE TO CRANK THE ENGINE UNTIL IT STARTS (UP TO 5 SECONDS) MAY RESULT IN LONGER CRANK TIMES OR HARD TO START CONCERNS ON SUBSEQUENT STARTING ATTEMPTS. IF THIS CONCERN OCCURS REFER TO THE OWNER'S GUIDE FOR FURTHER ENGINE STARTING INFORMATION. IF VEHICLE STILL FAILS TO START OR STILL EXHIBITS HARD STARTING CONCERNS REFER TO THE PC/ED MANUAL FOR DIAGNOSTICS.
EFFECTIVE DATE: 03/13/2006
-Ryan
abilath is offline
